[FP] ZK - Wake Me Up w Cake|FloRida-Avicii-MandiSeekings
Post Sat Aug 31, 2019 12:16 am
ZooKreeper - Wake Me Up With or Without Cake (Flo Rida vs Avicii vs Mandi Seekings)
Flo Rida & 99 Percent - Cake Instrumental
Avicii ft. Aloe Blacc - Wake Me Up Acapella
Mandi Seekings - With or Without You Acapella
v2
v2 Download
v3
v3 Download
v4.0
v4.0 Download
v4.1
v4.1 Download
Re: ZooKreeper - Wake Me Up w Cake|FloRida-Avicii-MandiSeeki
Post Wed Sep 04, 2019 11:38 am
I'd love some feedback on this if anyone has some :1smiley:
Post Wed Sep 04, 2019 8:12 pm
I like the combination. :1smiley:
What stands out to me is the use of Mandy's acapella. Are you intentionally using the off-timing effect? There are times when it seems that you want her singing the same way that U2 would have sung it, hitting on the syncopated rhythm, but you seem to want to have her sing it more straight. I think that the mix might sound better with the more traditional placement of the vocals.
Either way, there are times when Mandi is falling behind the instrumental. It is especially noticeable near the end of the mix.
Otherwise, there is a section right after the 2-minute mark that sounds rather confusing to me.
I hope you will give us a version 2 of this.
Post Wed Sep 04, 2019 8:54 pm
satis5d wrote:I like the combination. :1smiley:
Thanks for the feedback! Could you be a little more specific about the section that's confusing you? I'll take another crack at Mandi's timing :1grin:
Post Wed Sep 04, 2019 10:17 pm
v2 is up, started more or less from scratch on With or Without You. I think I kind of chopped and screwed it on v1 and this time I fiddled with the tempo first, then directly copy and pasted with a couple tweaks here and there. Hope it's better :1huh: I've listened to it so many times in a row I don't know if I can tell anymore XD
Post Thu Sep 05, 2019 1:47 am
I think you could title it, “Wake Me Up With Or Without Cake” to get full representation of the songs in there, but I digress…
The Mandi timing still seems hit or miss with V2. The verse section seems a beat or two early still, but the “with or without you”s around 0:37 seem to be right on time. The bridge “and you give…” sounds great too. If you go back and listen to the original “With Or Without You”, the vocals don’t come in until about 2.5 beats into the first bar of each stanza. I think you have her coming in after half a beat. Hope that explains it a bit better.
At 2:01-2:17ish you’ve got the “cake cake cake”s in the background and it really conflicts with Aloe Blacc’s vocal rhythm there--those two parts just aren’t rhythmically compatible. I’m sure that’s what satis5d was talking about. Some possible solutions could be: 1) just remove the Aloe vocals there; 2) loop a different section of the instrumental there under Aloe; or 3) chop and screw Aloe’s vocals to match/complement the “cake”s better there.
…or maybe you have another idea on what to do there! It all depends on your artistic vision there and how it affects the progression and flow of the track. We won’t tell you how your track has to sound--we’ll just tell you if something doesn’t sound right and give you some suggestions! Best of luck!
Post Thu Sep 05, 2019 2:21 pm
MashGyver wrote:I think you could title it, “Wake Me Up With Or Without Cake” to get full representation of the songs in there, but I digress…
I was trying to save space and time by leaving "or without" out of the title (and also denying people the option of waking me up without it, because why would I let them? :1wink: ) but you're right. It makes more sense this way, so I've updated the title and the cover art :1grin:
And this is where my inexperience really shows I guess. Tried again to fix Mandi's timing and hope I did better this time. I also looped a different section of the instrumental under Aloe's second set of vocals.
I'll keep trying to fix it as long as you guys are willing to keep listening! Thank you for your patience and all the help!
Post Fri Sep 06, 2019 1:15 am
I like the combo, was surprised by Aloe Black. Only deyail remark is that around 1.30 (before and after as well, i am listening on phone) he seems 'dragging' the mix, like he is a tiny bit late ?
Post Fri Sep 06, 2019 12:25 pm
CVS wrote:I like the combo, was surprised by Aloe Black. Only deyail remark is that around 1.30 (before and after as well, i am listening on phone) he seems 'dragging' the mix, like he is a tiny bit late ?
The only vocal tracks I've been able to find all seem to lag a bit and have really strong drum beats still underneath them during that part (and it happens in both choruses) that conflict with the beats from the instrumental, and I haven't been able to figure out how to fix it yet. Another instance where I think if I knew more I'd be able to do something about it :1cry:
Post Fri Sep 06, 2019 12:50 pm
Sounds quite professional, but why not the original U2 acapella? Who is Mandi Seekings?
Users browsing this forum: richc100 and 22 guests
