Ableton Live acapella quality remastering help
Post Fri Jul 03, 2015 5:36 pm
I have an acapella in Ableton that I have "warped" in order to change the tempo of it to match with an instrumental:
What is the best way of making it sound cleaner and less robotic?
Any help would be appreciated..........
Re: Ableton Live acapella quality remastering help
Post Tue Jul 07, 2015 4:17 pm
JamiePr wrote:I have an acapella in Ableton that I have "warped" in order to change the tempo of it to match with an instrumental:
See where it says 'texture', click on that and change it to 'complex pro' :1cool:
Post Wed Jul 08, 2015 1:57 pm
I don't have that option on my version :1huh:
Post Wed Jul 08, 2015 4:25 pm
What options you got? Complex should also work
Post Thu Jul 09, 2015 11:43 am
I only have the first 4, so must have a different version to you then.....
Post Thu Jul 09, 2015 2:56 pm
In which case, I suggest adjusting bpm and/or pitch in Audacity, or another DAW and then transferring it over (though ableton is free so probably the best bet)
Or upgrade your version of Ableton! :1laugh:
Users browsing this forum: No registered users and 1 guest
