does anyone know how to work audicity?
Post Thu May 21, 2015 2:40 pm
I am trying to mash together three songs. and I am having trouble figuring it out. if you can help, pm me thanks
Re: does anyone know how to work audicity?
Post Thu May 21, 2015 3:17 pm
Hey man, welcome to mashstix!
Personally I would advise against using audacity for making mashups simply because it's designed to edit individual tracks/sounds not as a tool for making a remix or mashup. Therefore it's very tedious and time-consuming to create anything in terms of a mashup which would sound good.
Here's a quote from a music website (E-Home Recording Studio) which I find particularly relevant:
"Yes, it’s true…free DAW’s do exist.
And no matter how many people say they’re a waste of time…
It’s a lesson most people must learn for themselves.
Now at this point, you have two choices:
Waste 2 weeks playing with Audacity, only to decide you need something better.
Or skip that part, and get something better now. "
Post Fri May 22, 2015 2:30 pm
I totally agree with Firth.
I tried to do a mashup using Audacity and I can say from my own experence: It is not a good tool to create mashups.
So if you are a beginner and want to start doing mashups I recommend using a "real DAW". You can use REAPER which you can try for free. So you can try it first. And if you get hooked you should buy a professional DAW. The are so many available even for a small budget.
Even though you technically could use Audacity to creta a mashup and it a very good piece of software. It is not a good tool to do mashups
Void
Post Fri May 22, 2015 5:10 pm
I just, I need something that would be 100% free and effective.. as I am really tight with money. any suggestions? sorry for being annoying
Post Sat May 23, 2015 7:39 am
britula143 wrote:I just, I need something that would be 100% free and effective.. as I am really tight with money. any suggestions? sorry for being annoying
The only free one I've heard of is this: http://zynewave.com/podium-free/
No idea how good it is though.
Users browsing this forum: Exabot [Bot] and 1 guest
