[FP]CVS - Lean On & Just B Good 2 Me (Major Lazer+Beats Int)
Re: (!)CVS - Lean On & Just B Good 2 Me (Major Lazer+Beats I
Post Mon May 25, 2020 7:50 pm
CVS wrote:after some breathy/airy vocal Google-research I made a new version 3, now in the O.P.
For future reference, I discovered that the (free vst plugin) T-SLEDGE has a preset called "Air" and it definitely does the job.
Post Sat Jun 13, 2020 1:28 pm
Bump, thanks warezio, tsledge is now in my toolbox.
Post Wed Jun 17, 2020 1:13 pm
Great idea, I like it very much :1cool:
My only comment is that I'm missing the structure of verses and chorus here :1undecided:
The first verse from the acapella continues on the "Lean On" chorus and from that point, it loses the sync between the sources (at least most of the time).
It might be difficult to use the first verse as it is because of its length, but maybe, just as a suggestion, you can use the original vocals from "Lean On" here and there to overcome that issue.
Hopefully, you'll find the way, cause I really like this combo :1wink:
Post Thu Jun 18, 2020 9:59 am
Thanks Smash for your review and tips. I restructured the mental by reusing/repeating parts, to create enough room for the first long verse in new version 4, now in O.P.
Post Tue Jun 23, 2020 4:26 pm
I'm a YES to this one! :1cool:
Re: [FP]CVS - Lean On & Just B Good 2 Me (Major Lazer+Beats
Post Wed Jun 24, 2020 1:28 am
Thanks guys for the tips and Frontpage !
Previous
Users browsing this forum: MorrisBX and 24 guests
