Marinmashup - Between the deep (French 79 vs Adele)
Post Wed Mar 18, 2020 7:03 pm
Instrumental : FRENCH 79 - Between the buttons
Acapella : Adele - Rolling in the deep
I'm stuck at home so i decided to put online some mashup ! If i can have some good advices (as usual) it will be perfect !
V1 :
https://sowndhaus.audio/uploads/tracks/ ... 757179.mp3
V2 :
https://sowndhaus.audio/uploads/tracks/ ... 401732.mp3
Re: Marinmashup - Between the deep (French 79 vs Adele)
Post Fri Mar 20, 2020 7:19 pm
What can I say? Adele excites me even less than she did 8 years ago, but the fresh instrumental saves her here. Not the most exciting, energy packed song, but it sounds good. The chords in chorus aren't what I would expect with her sung notes in chorus, but they work, and the softer parts in instrumental that her chorus vocals also sit on sounds really nice.
Only thing I could find in whole mashup that could potentially be fixed is a quick, minor vocal glitch @ 0:52, sounding like maybe you cut the vocal track here, but didn't cross it over with next part to let it blend. A simple fix most likely if you want to go back and make this 100% instead of 99.5%. ★
Star Man audiovisual transmission logs: https://www.youtube.com/channel/UCqb33w ... ns9DMeHKgA
Post Sun Mar 22, 2020 5:18 pm
Thanks for your comment ! I will look at this moment, but I think it's the acapella which is like that.
Post Sun Mar 22, 2020 10:18 pm
marinmashup wrote:I think it's the acapella which is like that.
Looks like you're right (@ 0:19 in video below):
You could still fix it if you want with some creative blending, but I don't even know if moderators would mind it in the first place.
I'm guessing whoever produced her song made a cut there, and you just can't really hear it well with the instrumental, so they didn't feel a need to blend it better, but people making mashups with other instrumentals might show it a lot better, like yours.
Post Tue Mar 24, 2020 4:21 pm
I would definitely recommend this if you fix the glitch previously mentioned. A 15-minute fix of creative blending to fix a 0.15 second error. :1undecided:
Definitely deserved one thumb up as-is, though.
Post Thu Mar 26, 2020 4:30 am
Hello, I fix this little glitch. I just remplaced with another part of the song. Tell me if you think is correct
Users browsing this forum: Google [Bot] and 26 guests
