DJ Surda - Lady Gaga vs. The Cardigans vs. Rick Astley
Post Wed Mar 11, 2020 8:32 pm
Hi
I want to share my newer mashup between Stupid Love by Lady Gaga, Lovefool Aca by The Cardigans & Never Gonna Give You Up Aca by Rick Astley.
I did 3 versions, 2 a+b mashup versions & the last as a combo of all 3 songs.
Do you think all work well?
Lady Gaga vs The Cardigans
Lady Gaga vs Rick Astley
Lady Gaga vs The Cardigans vs Rick Astley (combo version)
Covers in the following days!!
Thank you!!
Re: DJ Surda - Lady Gaga vs. The Cardigans vs. Rick Astley
Post Tue Mar 17, 2020 11:40 am
Anything I can listen to?
Firmly anchoring the old and untalented end of Mashstix since 2012...
Post Tue Mar 17, 2020 2:28 pm
Thanks Mike,
Under each version name appears a black image, if you click, your browser will enable the plugin for the player. Once you did that the players will appear authomatically (until you close the browser), at least this is how this works to me...
The links are from my website but it works like this with all links now, i do not know the reason.
Post Tue Mar 17, 2020 7:38 pm
DJ Surda wrote:Hi
Thank you!!
Interesting. None of the links appear on my view of the post. Mousing over the page produces no results. By quoting your post I see some links that I can copy and paste. Time to call my IT guy...
Post Wed Mar 18, 2020 5:15 am
I do not understand why it does not works fine. I used the rules from the **Mashstix: How to Post Your Track (Please Read)**
The links are these:
Lady Gaga vs The Cardigans - https://djsurda.pro/wp-content/uploads/ ... -demo1.mp3
Hope this works
Post Wed Mar 18, 2020 10:08 am
Thanks. I was able to copy and paste the links from the pre-post text of a quote of your post. Once I submitted the quote and my remarks, the text with the links disappeared and the words 'no flash installed' appeared in their place.
Post Wed Mar 18, 2020 11:17 am
The mp3 player works fine for me on all 3 mixes. No issues there.
For me, the first one, the combination of Gaga and the Cardigans is far and away the best option. Rick is singing in the same key, but he's a few cents off from Gaga's instrumental which makes for sound clashes at times. The combo version is missing the instrumental, so I have no idea how that really sounds.
But I'm prepared to recommend the Gaga/Cardigan version. It's great! :1cool:
Post Thu Mar 19, 2020 2:11 pm
satis5d wrote:The combo version is missing the instrumental, so I have no idea how that really sounds.
Combo version is now fixed!
satis5d wrote:Rick is singing in the same key, but he's a few cents off from Gaga's instrumental which makes for sound clashes at times.
Do you think Astley is late or he is earlier?
Thanks for the feedback!!
Post Thu Mar 19, 2020 11:48 pm
Whar Satis5d means is the pitch of Rick.
A semitone difference (like between F and F#) is divided in 100 percent.
At the place in your DAW where you can change the pitch (of a vocal), you can change in full semitones, but ALSO in a percentage of a semitone. (So before, and after the decimal point).
On one of my mashups, Satis5d pointed out a 0.25 (so quarter of a semitone) difference. I think for your mashup he means even less "cents". Maybe 0.10 is a good starting pount ? Switch back and forth (or change just the firstsenyence and not the second) and use your ears to find the right pitch percentage.
Post Sat Mar 21, 2020 2:18 pm
CVS wrote:Whar Satis5d means is the pitch of Rick.
Thank you.
Now i understood i missunderstood satis5d.
Rick is OOK not OOT.
My DAW is Ableton Live.
Ive tested changing cents of the key but honestly i can detect wich is the best. Here are some key changes, can you provide feedback of which works best?
-50 cents
-25 cents
-12'5 cents
0 cents
+12'5 cents
+25 cents
+50 cents
Thanks, really appreciate it!
Users browsing this forum: No registered users and 23 guests
