CVS - It Ain't Me Whistle (Flo Rida + Kygo + Gomez)
• Page 1 of 1
Florida - Whistle (acapella) C maj - 103,96 bpm
Kygo + Selena Gomez - It Ain't Me (instrumental) C maj - 100 bpm
thanks Smash for your review on version 3, yeah I see now it is a mirror of your earlier mashup
version 4:
- moved vocal placement back about 4-5 seconds
- EQ on vocal (less bass below 250 and less very high and Sony Noisegate nr. 2
- cut out blank spaces in vocal to get rid of artifacts, and to match pella to changes in mental
- switched the mental to 'one shot'
- volume changes on vocal and send-reverb on that
- cut out echo effects completely, gave more mental outro to let cut off vocal 'breathe'.
download-version-4
to compare, older versions below:
Thanks for your review HCD on version 2
I took out some parts of pella to make it fit the mental better.
Kickdrum should start now 'everywher' on can-you-blow-my-WHIS-tle-baby.
Fade in on pella to introduce the (I know...) very early vocal start.
I cut most of the echoes but there is still some Camelspace Echo VST on a seperate track on the 'here we go'. Had to kill the last 'here we go'.
I believe there is some syncopation going on now with Flo Rida.
version 3:
download-version-3
version 2:
Lots of Camelspace echo on Flo' on a seperate track.
download-v2
- Happy Cat Disco
Re: CVS - It Ain't Me Whistle (Flo Rida + Kygo + Gomez)
I like the pairing but I'm missing the structure. I think the verse / chorus needs to be closer between the two songs.
thanks HCD, I worked on the structure, new version in the O.P.
Remind me one of mine
http://www.mashstix.com/005486
Version 3 still missing the structure, at least at the very beginning, and it might affect the rest of the track.
In both original songs, the vocals first introduced around 0:09, so I think it might help if you can use the whistles as they apears in the original "Whistle" song.
In addition, you are using a DIY acapella, you can hear it well in the first part. Try to clean it more, if you can, or at least remove the empty parts between the singing
Thanks Smash, I moved the vocal placement to the back, and also cut out 'blanks' from the vocal track to get rid of the artifacts and put a noisegate (and EQ) on vocal, see new version in original post.
• Page 1 of 1
Users browsing this forum: Google [Bot] and 35 guests
