(FP)CVS - Return of the Idgaf (Mark Morrison + Dua Lipa)
Well...
Post Thu Jul 18, 2019 8:57 am
As for the leveling and EQ'ing, it's now on spot!
The varispeed is, however, a debatable solution there. While the mods would mostly accept it, I would give the other V5 a shot to make sure that this gets FP'ed. Too bad your Dropbox is on limit by now... :1undecided:
So what you have to say, possible FrontPager? (for the mods, of course :1laugh: )
Re: CVS - Return of the Idgaf (Mark Morrison + Dua Lipa)
Post Thu Jul 18, 2019 1:20 pm
Thanks Gladilord, for replying so fast.
No faz mal, I put up the fast version (= like version 4, EQ'd and saturarated but not slowed down) on Sowndhaus.
When (if...) a version is FP-picked, I will clean up old versions. And start using a newer version of Chrome (and another, newer computer I fear) :1embarassed:
Post Sun Jul 28, 2019 2:55 pm
Nice combo, verison 5 sounds much better, but I think you can improve the pella by lower down the mid-range freq a bit.
Post Mon Aug 05, 2019 11:33 am
Thanks SMASH for your review. I lowered the EQ in the midrange, new version is in O.P.
I have found a workaround for my Dropbox problem.
Post Mon Aug 05, 2019 12:22 pm
Sounds really good, CVS! If I’m being picky, the lead vocals are still a little distant in the mix. If you have added any reverb yourself, it might be too much. If not, there aren’t many (simple) things you can do besides continue to tweak the EQ. Honestly, sounds really good!
Post Tue Aug 06, 2019 2:15 pm
Sound much better :1smiley:
MashGyver wrote:Sounds really good, CVS! If I’m being picky, the lead vocals are still a little distant in the mix. If you have added any reverb yourself, it might be too much. If not, there aren’t many (simple) things you can do besides continue to tweak the EQ.
I agree with MashGyver's comment, can you please check his point?
Re: (!)CVS - Return of the Idgaf (Mark Morrison + Dua Lipa)
Post Tue Aug 06, 2019 2:30 pm
Thanks MashGyver and SMASH, I just put up a new version in the O.P.
A lot less (send) reverb on the vocal, and a bit more vocal volume just to be sure.
Left the tape saturation on vocal as it was.
Made the EQ dip on vocal a tiny bit deeper.
Post Mon Aug 12, 2019 12:38 am
bump, thanks MashGyver and SMASH, I just put up a new version in the O.P.
Post Sat Aug 17, 2019 11:27 pm
V7 sounds much better. I maintain my recommendation! :1smiley:
Post Fri Aug 23, 2019 5:38 am
Thanks MashGyver for your repeated recommend :1laugh: .
Now if one of the other mods....
Or if Gladilord were a mod...
Or if SMASH returned...
PreviousNext
Users browsing this forum: No registered users and 31 guests
