(FP)CVS - Havana-nananana (Cabello vs. Eminem)
Re: (!)CVS - Havana-nananana (Cabello vs. Eminem)
Post Sat Aug 17, 2019 11:39 pm
Fun combo, CVS! I will agree with jimmylin--the transition at 1:53ish also sounded rough to me. I don’t have any suggestions for you there unfortunately.
EQing sounds good, and the rest of the editing seems fine. There is just a bit of a tuning disparity between the instrumental and vocals, though. As far as I can tell, the vocals are a bit flat. So I would bring them up 30-40 cents and see if they lock in any better.
Best of luck!
Post Fri Aug 23, 2019 5:31 am
Thanks Jimmylin and MashGyver for your reviews, tips and copliments.
I tried to 'unjar' the transition (lower volume, placing Em's 'attention please' slightly later, moving the real rap). Also pitched the vocal (Camila and her rapper) up 30 percent of a semitone. New version is in O.P.
Post Sat Aug 31, 2019 12:40 pm
Bump, remarks of have been fixed
Post Tue Sep 03, 2019 12:02 am
You know what, CVS? I was wrong about the pitch…listening now I think I’ve led you in the wrong direction. V5 still sounds a bit off, but it is way better than V6, pitch-wise. :1huh: I’m not sure what I heard last time…
You can maybe try bringing the vocals down 10-15 cents from where they were in V5. I apologize…this is something you may have to “Trial and Error” just by ear.
Post Tue Sep 03, 2019 2:59 am
Thanks MashGyver, I lowered the vocal pitch to minus 10 percent in version 7 in O.P.
In version 6 I chose the 30 percent up.
Post Sat Sep 07, 2019 7:11 am
Bump, i changed the pitch like you suggested MashGyver
Post Mon Sep 09, 2019 11:44 pm
V7 sounds much better, CVS. Sorry for sending you on the wild goose chase!
Re: (FP)CVS - Havana-nananana (Cabello vs. Eminem)
Post Tue Sep 10, 2019 2:25 am
Thanks all for time, reviews and FP and especially MashGyver.
No apologies needed, I am glad that you help.
Previous
Users browsing this forum: No registered users and 36 guests
