CVS - Don't You Wish I Saved Your Life (PCD + Indeep)
Post Sun Jun 02, 2019 9:28 am
Indeep - Last Night A DJ Saved My Life (instrumental) F# minor
PCD - Don't You Wish Your Girlfriend (acapella) G# major, so relative F minor
Thanks for your review Satis5d on version 3, I called Autotune to the rescue and lowered vocal 2 semitones (keep formants) and forcing the resulting F# major it to F# minor.
Added a sample about 'fixing it in the mix' in the outro.
Minor fixes in vocal placement. A bit more delay on some last words, that fits better with the jingly-jangly guitar parts.
download-v4
------------- to compare older versions below --------------
Thanks for the review Dra'man on version 2, I found the combo thinking both were in B major, but Melodyne helped me to keys above.
Version 3 (pella up one semitone with keep formants, about half of mental is non-tonal rap, also improved some vocal placement, finetuned delays in last minute).
Re: CVS - Don't You Wish I Saved Your Life (PCD + Indeep)
Post Mon Jun 03, 2019 6:29 am
what is that mental version ? (i like it)
about the mashup: The pella is OOK :1wink:
Post Tue Jun 04, 2019 2:42 am
Hi Dra'man, the mental is a instrumental remake, my standard Indeep mental.
I found out this is a pella maj + relative minor mental combo, but with a lot of rap in the mental. So I put up a new version 3 in the O.P.
Post Tue Jun 04, 2019 7:08 pm
It's definitely a lot better than the last version, but there are several parts that are still OOK. I'm not sure if this one is salvageable CVS. :1undecided:
Post Thu Jun 13, 2019 1:32 am
thanks Satis5d for your comments, new version (this time vocal two semitonre LOWER and changed from major to minor) in O.P.
Post Tue Jun 18, 2019 5:48 pm
I'm still hearing some OOK notes from the Pussycat Dolls in the 1:50-2:20 section.
Users browsing this forum: No registered users and 39 guests
