(FP) CVS - The DIRRTY Message (Aguilera + Flash)
Post Mon May 06, 2019 6:39 am
Christina Aguilera ft. Redman - DIRRTY (acapella)
Grandmaster Flash and the Furious 5 - The Message (full vocal) - chopped and reordered
version 7 thanks Satis5d for the two-thumb recommend, and SMASH for the one thumb, I now made a smoother outro with wordplay on cars, carpark and cops but this makes the mashup longer. But it is still about half a minute shorter than early versions like Dra'man suggested below (see his: would be perfect if shorter). I hope Satis5d is still satisfied with this version 7 haha :1wink:
downlload-version-7
If you want to compare:
version 6 - thanks Dra'man for your second review on V5
I cut out (in the middle) a minute of second half, shortening mashup from 4:56 to 3:55,
so rearranged mental and used some other rap-parts. I made a cutup @2:55 to transform the 'car' to 'cut' (for Dra'man :1grin: ), hope 'he like that', this hard cut-outro with reverb, for SgtMash is removed in version 7.
version 5 (long) - thanks Dra'man for your review on V4
I replaced ALL parts where the mental under Christina had no bass, with parts with bass.
version 4 - thanks Satis5d for your review on V3
new outro,
new combination of mental + vocal parts from the Message (longer parts as well),
better placement of pella on mental,
fixed remaining timing issues in xtina's vocal, also in intro,
removed repeat edits from V3.
version 3 (the first posted on Mashstix)
A long one (in this version), but for SMASH :1grin: I used original vocal as well.
Used dirty bits of the rap (peepshow) to combine with Christina. A-ha-ha-ha-haa !
Re: CVS - The DIRRTY Message (Aguilera + Flash)
Post Fri May 10, 2019 5:26 pm
There are timing issues with Christina starting in the 1:50s. Gotta fix that first.
Post Mon May 13, 2019 12:33 pm
Thanks Satis5d for your comment, new fixed version is in O.P.
Post Wed May 15, 2019 4:45 am
i like it, i think the bass is missing on the 1st verse of Christina (this part is boring)
Post Wed May 15, 2019 1:00 pm
Thanks Dra'man for your comment, the bass was missing on more xtina parts, they are all fixed now in new version 5 in O.P.
Post Thu May 16, 2019 12:39 am
CVS wrote:Thanks Dra'man for your comment, the bass was missing on more xtina parts, they are all fixed now in new version 5 in O.P.
Thank you mate, i love it, it could be perfect to me with a shorter last part. you can reduce it by at least 30 seconds :1wink:
What do you think about this suggetion ?
Post Thu May 16, 2019 3:48 am
Thanks Dra'man for the fast second listen, I took out a whole minute, new version is in O.P.
Post Mon May 20, 2019 4:52 pm
I only listened to the latest version, but that sounds really good to me CVS, Well done ! :1cool:
Post Wed May 22, 2019 1:18 pm
Thanks Legato for your compliment.
Post Fri May 24, 2019 3:52 am
Nice, and thanks for adding the original vocals (maybe a little too much :1smiley: )
To be honest, I didn't fell off the chair with that one, so I'll give it one thumb up :1wink:
BTW, maybe you need to find a better way to end it, currently, it is kind of abrupt ending :1undecided:
Users browsing this forum: Google [Bot] and 41 guests
