Mama, hier kommt die Sonne - Rammstein vs. Genesis
Post Tue Apr 02, 2019 1:30 pm
Just got a weird idea. Hope you like it either:
Mama, hier kommt die Sonne (4:48 min)
Instrumental: Rammstein – Sonne
Acapella : Genesis – Mama
ENJOY!!!
Re: Mama, hier kommt die Sonne - Rammstein vs. Genesis
Post Wed Apr 03, 2019 6:52 am
I like the idea and how the acapella fits on the mental in the breaks. Gut gemacht.
But the vocal is too soft (FOR ME, on headphones), and sounds a bit to the right (so not in the middle), and is maybe mono (from the original stems?).
Maybe stereo-izing the vocal (split to L+R and delay one of them a few milliseconds) will help, if it is mono now.
Post Wed Apr 03, 2019 10:00 am
Thanks for the reply
I mentioned too that the vocals of the verves are very smooth.
So I already put a lot of compression on it, put the low frequences up.
And, in addition, I reduced the stereo effect to make them sound more straight.
I think, in the refrain the vocal fit perfectly; especially the parts Phil Collins shouts!
Maybe I'll try to give the vocal in the verves even more power
Post Wed Apr 03, 2019 12:18 pm
Just produced version 2 with much more power on the verve vocals.
Link remained
Hope, that's better now!
Post Fri Apr 05, 2019 3:06 am
Hi ! i like the idea, the chorus is ok but the verses are out of key.
Post Sun Apr 07, 2019 10:15 am
I think it's quite diffical to find the right key in the verves, because the Rammstein accord itself is very unharmonically.
So I've pitched the vocal a little bit down one more time.
Hope that's better now!
Post Thu Apr 11, 2019 1:14 am
Interesting idea, Hahnstudios! That Rammstein ‘mental hits really hard and it’s cool to hear the clash of styles here. I can agree with the others that the harmony isn’t quite working, though...
Sounds like the Rammstein verses are in D minor and the chorus is in B minor…that already makes this a tough hill to climb. Meanwhile “Mama” seems to be entirely in E minor, which might explain why it sort of works in the chorus (fifth apart) and not in the verse…
Not sure if there’s an easy fix here, honestly. Bringing Phil down 2 semitones during the verses and 5 during the chorus would be a bit drastic… :1undecided:
Post Thu Apr 11, 2019 4:28 pm
I am probably going to say a lot of what Angus said but in a slightly different way, Anyways, the vocals are barely audible I would increase the high end of the vocal maybe add a flanger effect and some additional reverb, Maybe keep the Mama Chorus and use another genesis song that's in D Minor for the verses and you should be fine. And yes the Chorus sounds fifthy cause it's E Minor and B Minor in that section but it works as Angus previously said.
Users browsing this forum: Bing [Bot], CVS and 36 guests
