(FP)DJDumpz - You Don't Know Mercy (Duffy,ArmandVanHelden,+1
Re: DJ Dumpz - You Don't Know Mercy (Duffy,ArmandVanHelden,+
Post Thu Jan 10, 2019 3:20 pm
HCD thanks a lot for your advice! :1smiley:
I tried to follow your "tutorial" and it was quite easy as I'm also using Fab Filter MB for SC MB compression. However, I can't get the bands as small as you said. My minimal bands for me are
750Hz-1.5kHz
1.5kHz-3.0kHz
3.0kHz-6.0kHz
Is there any setting with which I can unlock smaller bands? Or is my version just outdated? :1undecided:
SgtMash wrote:What HCD said...I was gonna say "some selective EQ is all you need as there's a lot at the top" and HCD went all extra helpful n technical for ya :1grin:
I like the pairing bangs along nicely!
Thanks. I hope the mix will get better in the next version! :1wink:
Post Fri Jan 11, 2019 11:52 am
Good to see you again, Dumpz, and nice pairing :1smiley:
I can only add that the vocals sound a bit dry to my ears. Waiting for your next version :1wink:
Post Fri Jan 11, 2019 9:46 pm
Those Frequencies ranges are ball park so.. no, I bet your range will work fine. :1smiley:
Post Mon Jan 14, 2019 11:14 am
V3.0 is done. I improved the SC multiband compressor as suggested by HCD to give the vocals more space. :1smiley:
Let's see if this did the trick...
Happy Cat Disco wrote:Those Frequencies ranges are ball park so.. no, I bet your range will work fine. :1smiley:
Just curious: Do you always use roughly these frequency bands for all vocals or is this different for each mashup?
Post Mon Jan 14, 2019 9:04 pm
V3 sounds good to me. The extra effort helped and we all learned something in the process.
Post Tue Jan 15, 2019 8:38 pm
Sending is up. Very clear now. Great Job!!
DJ Dumpz wrote:Just curious: Do you always use roughly these frequency bands for all vocals or is this different for each mashup?
Bit of both. Ball park is within 100Hz. Most vocal issue are as follows
  • Kick bleed or low noise 100Hz and lower
  • Muddy vocals 300Hz to 500Hz lowered in the vocal (EQ)
  • Vocals Are Tinny Increase 300-500-600-800Hz via Expander (EQ and Multiband Expansion)
  • Can't hear vocal vowels 700-900Hz This rarely happens but when it does it's lowered in the instrumental (EQ - Multiband)
  • Over nasal quality from a vocal filter typically 800Hz Male to 1kHz for Female lowered in the vocal
  • Sharp but can't put your finger on the range is typically 1kish and just needs to be controlled via Multiband
  • Vocals getting buried is typically 1k - 1.3 kHz lowered in the instrumental (EQ - Multiband)
  • To much noise or brass is in the way 1.3 - 3kHz lowered in the instrumental (Multiband)
  • Something is hurting my ears, Typically 3.3kHz - 3.5kHz lowered in the vocal (Multiband)
  • The vocals are too bright or the triangle percussion is too loud 5kHz lowered in the vocal or instrumental (Multiband)
  • The Esses are to piercing 7HZk - 7.5kHz and 9kHz -11kHz
lowered in the vocal (Multiband or Dessers)
The ranges change a little if you pitch. But every song might require treatment in these areas. The only time you have to hit all of these is in a mega mashup.
Re: (FP)DJDumpz - You Don't Know Mercy (Duffy,ArmandVanHelde
Post Thu Jan 17, 2019 4:15 pm
Thanks guys for the FP! :1cool:
And special thanks to HCD for all the technical help and explanations. Learnt a lot on this one! :1smiley:
Post Sat Feb 02, 2019 12:03 am
Where is the like button for this thread??
Good job guys!
Post Sat Feb 02, 2019 6:43 pm
DJ-SS wrote:Where is the like button for this thread??
Good job guys!
Haha, this is a forum and not facebook but thanks! :1grin:
Previous
Users browsing this forum: No registered users and 17 guests
