(FP)Can't Remember The Dance(MeghanTrainor v MichaelJackson)
• Page 1 of 1
SMASH - Can't Remember The Dance (Meghan Trainor vs. Michael Jackson)
Instrumental & Vocals: Meghan Trainor - Can't Dance
Vocals: Michael Jackson - Remember The Time
This mental gives more energy to MJ, hope you like it
V2
Re: Can't Remember The Dance (Meghan Trainor x Michael Jacks
Wow SMASH! This sounded really well, very "dancy" mental track and it fits right in
You're on fire lately! Another good one.
There are a couple of "remember the time's" near the end that sound a little off to me. It's forgivable, but I think you can make them sound better.
After satis5d listened to it and gave his feedback, i must agree.. there is a somewhat key-issue at about 02:45 ish, but i don't care, it still sounds golden to me
Yeah it sounds great, almost like shining / beautiful glance, something you did in the mastering I guess.
I don't remember (haha) from the original the 'remember the times' at the end that change in pitch and sound like a harmony effect. So maybe you made them yourself with a plugin changing the pitch some steps at the time? These could be the points satis5d and legato mentioned.
:) Fantastic - if I was being greedy you coulda echo'd out the last syllable on the vocal to avoid the abrupt ending cut feel or used a signature Heehee or hooo and revb to give it a sonic tail out <3
but idk it matters really tis superb
Thanks, guys, for the comments and compliments
Ok, I think the problem is with the background vocals, so I guess there's nothing much I can do, unless a multitrack is available
But I had another solution, I changed the ending by using more from the original "Can't Dance", hope it sounds better now.
Version 2 is up
satis5d wrote:There are a couple of "remember the time's" near the end that sound a little off to me. It's forgivable, but I think you can make them sound better.
Dj-Legato wrote:After satis5d listened to it and gave his feedback, i must agree.. there is a somewhat key-issue at about 02:45 ish, but i don't care, it still sounds golden to me
CVS wrote:I don't remember (haha) from the original the 'remember the times' at the end that change in pitch and sound like a harmony effect. So maybe you made them yourself with a plugin changing the pitch some steps at the time? These could be the points satis5d and legato mentioned.
Version 2 is up
Indeed it does!SMASH wrote:This mental gives more energy to MJ, hope you like it
• Page 1 of 1
Users browsing this forum: Exabot [Bot] and 39 guests
