(!)Prince Vs. Phil Collins Easy Lovin Thieves
• Page 2 of 3 • 1, 2, 3
Re: Prince Vs. Phil Collins Easy Lovin Thieves
I'm digging V3. The mix and relative vocal/inst balance sound good to me.
Minor nit: when I do these 80s-style fade-outs, I try to put a bit of the mashed-up acapella in it; this one is just the Phils, maybe sprinkling some Prince in there would help cement the illusion.
Keep raidin' them Paisley Park treasures, you are onto something here.
warezio wrote:I'm digging V3. The mix and relative vocal/inst balance sound good to me.
With Prince where does one even start? Dude has 35 albums at least the ones I know of! Maybe SOTT or DMSR is next, Yeah I might include Phil instead of the karaoke singers towards the end, Let's see what the others think and sorry for the delayed response!
Well, I have to say the instrumental still sounds a bit weak, even when compared to the YouTube version of it…I don’t know if that’s just generational loss from ripping it to mp3, then re-rendering it, or what, but at least it’s better than it was in the previous version.
Instrumental quality aside, I can’t poke many other holes in this mashup. Great work!
MashGyver wrote:Well, I have to say the instrumental still sounds a bit weak, even when compared to the YouTube version of it…I don’t know if that’s just generational loss from ripping it to mp3, then re-rendering it, or what, but at least it’s better than it was in the previous version.
What happened was the person that posted that karaoke instrumental didn't have a download link so I recorded it via Audacity rendered the track in WAV Format, Then when I was doing the mix I rendered it again in MP3 format, So because I recorded it in Audacity rendered it in Audacity then re-rendered it in Reaper that led to some generational loss.
Re: (!)Prince Vs. Phil Collins Easy Lovin Thieves
I agree.
Not sure if you are using the same version, but this one sounds better to me...
Do iiiiit! It's gr8, but will be glorious with that Xtra bit o love <3 :)warezio wrote:+1. This can be epic if the instrumental is improved. I'll PM you.
SMASH wrote:MashGyver wrote:Well, I have to say the instrumental still sounds a bit weak
I agree.
Not sure if you are using the same version, but this one sounds better to me...phpBB [media]
Same one I am using.
SMASH wrote:TheRayMan wrote:Same one I am using.
Still, that one on YT sounds better![]()
Did you manipulate the mental in some way?
I did through a suggestion that warezio said there was a way to do it without generation loss but I right clicked properties it said it was 93 Kbps, So even if I did this without Generation loss it still wouldn't be great, Tried to find a better version on various karaoke sites yet the drums sounded weaker then in V3, In short most other karaokes were garbage, I don't know if I should continue or not I guess V3 is as good as it gets.
Users browsing this forum: Majestic-12 [Bot] and 103 guests
