(FP) Xouth - Fine Superstition(Chris Brown vs Stevie Wonder
Re: Xouth - Fine Superstition (Chris Brown vs. Stevie Wonder ft.
Post Tue Jan 10, 2017 8:53 pm
MashGyver wrote:V2 sounds much better! And it doesn’t lose any funkiness to me. The spot at 0:55 is extra funky, and I think that may be why the timing sounds off to satis5d, but I don’t hear anything wrong with it. “13 month old baby” still isn’t in the funkiest spot it could be in, nor is “good things in your past” at 3:01 (I didn’t catch this the first time), but I think those are okay if you leave them alone, honestly.
I feel like the ending still needs another second to decay. It is much better, but still drops off pretty suddenly. How about a version 2.1? :1smiley:
I’m interested to hear what SMASH thinks about the changes...
Ok i will fix the ending again :1grin: thanks for the advices guys!
Post Tue Jan 10, 2017 10:17 pm
I left V2.1 :1smiley: please check! :1wink:
Post Tue Jan 10, 2017 11:40 pm
Xouth wrote:I left V2.1 please check!
:1huh: It doesn’t sound any better to me :1sad: I listened to the original instrumental and sounds like it just fades out after that point. Could you just do a short fade out after that note? I like what you’re trying to do, ending on that big brass stab, but it needs a ton of reverb and/or delay to make it sound organic and smooth. What software are you using to make this, Xouth?
Post Wed Jan 11, 2017 12:12 am
This is what I mean for a natural ending with reverb:
XouthClip.mp3
All I did to get that sound is to fade out quickly after that big brass note, then put a bit of reverb on that note and let it ring for an extra second. Hope that helps!
You do not have the required permissions to view the files attached to this post.
Post Wed Jan 11, 2017 12:58 am
This is good Xouth! I like Mashes ending more, but this is a great edit as is as well. Nice work.
Re: (!) Xouth - Fine Superstition(Chris Brown vs Stevie Wonder
Post Wed Jan 11, 2017 3:09 am
I like the improvement of version 2.1, and I also feel more comfortable with the ending MG suggested.
Fix the ending and I'm sure that everyone will be satisfied :1wink:
Post Wed Jan 11, 2017 6:24 am
I think it's fine now, maybe it didn't work fine because i was trying to do it with a delay :1grin:
Post Wed Jan 11, 2017 8:37 am
Sounds good now! Great work sticking with it!
Previous
Users browsing this forum: Exabot [Bot] and 23 guests
